[QUOTE=juan;2736892]@elbuscavidas idk what you mean . if you read this thread, people still have lot of problems even when they follow the tutorial . but like I said try to build it on your own , if you have a problem ,people on this forum are willing to help.[/Q
I mean that the tutorial is updated. Thanks also Juan
Results 451 to 480 of 793
Hi all
Please, pretty please, refrain from hijacking this thread with any desire to extract emulated and/or real cdm. There are numerous threads discussing that and this a definitely not one of them.
Let's keep this thread on topic.
Regards -
it is posible to add manuel the pssh on the box ?
Try creating a new scheme and add the desired pssh as part of the call to pyodide -
Hey @FoxRefire, great work -- I see you didn't like my original API for Zanes extension, so I made an API for yours as well!
https://cdm-project.com/TPD94/CDRM-Extension-API/src/branch/wvg
I'd actually like to work with you to implement more features on the back end, as I don't want to have to dig through line by line of your code, but if not I get it!
Yours is now the default I'm recommending though, as it's not obfuscated.
For anyone who wants to check out the extension without a wvd file you can get my modified version that works with the API I wrote
https://cdrm-project.com/extension -
Hi FoxRefire,
Kindly and please reply to this post.
I am studying and comparing the background.js legacy code and the present code. There are two different lines of code that are really challenging and I am soliciting you help with respect to a solution. Thanks
code ... wvg-next line 13
Code:line 13 return JSON.stringify(Object.fromEntries(obj.map(header => [header.name, header.value]))) line 34 chrome.webRequest.onBeforeSendHeaders.addListener( function(details) { if (details.method === "POST") { window.requests.push({ url:details.url, headers:convertHeaders(details.requestHeaders), body:window.bodys.find((b) => b.id == details.requestId).body }); if(testBlock(details.url)){ return {cancel:true} } } }, {urls: ["<all_urls>"]}, ["requestHeaders", "blocking"] );
Code:line 4 return Object.fromEntries(obj.map(header => [header.name, header.value])) line 11 chrome.webRequest.onBeforeSendHeaders.addListener( function(details) { if (details.method === "POST") { requests.push({ url:details.url, headers:convertHeaders(details.requestHeaders) xxxxxxxxxxxxx no such line of code xxxxxxxxxxxxx }); } }, {urls: ["<all_urls>"]}, ["requestHeaders"] );
return Object.fromEntries(obj.map(header => [header.name, header.value])) // ... legacy code
// return JSON.stringify(Object.fromEntries(obj.map(header => [header.name, header.value]))) // ... next code
These seem to be equivalent .... but the next code seems to work only with pyodide not with legacy
the biggest challenge comes with this bad boy ... located in next code only
with this code the legacy system ... the extension will not start
and without this code there is no body element/section in the response json of the legacy extension.
Please kindly advise as to the correct code because there is a necessary requirement to having the body section included in the response.
Regards
First, the purpose of the convertHeaders() function is to convert HAR format headers to generic format as described below:
Headers in HAR format:
Code:"headers": [ { "name": "NAME-OF-HEADER1", "value": "VALUE-OF-HEADER1" }, { "name": "NAME-OF-HEADER2", "value": "VALUE-OF-HEADER2" } ]
Code:{ "NAME-OF-HEADER1": "VALUE-OF-HEADER1", "NAME-OF-HEADER2": "VALUE-OF-HEADER2" }
Pyodide automatically converts data of string and numeric types and can pass values between Javascript<==>Python, but object types and Bytes(ArrayBuffer) cannot be passed as is.
Therefore, it is necessary to convert the data once into a string before passing these data.
The request body cannot be retrieved at the same time as the headers and must be retrieved using separate methods, onBeforeRequest and onBeforeSendHeaders, respectively.
Therefore, when the request is related by comparing the requestId attribute, and the request body and headers are stored at the same time.Don't be stupid.Use your brain and Google.
Read the rules and documentation before asking for support about my extension. -
* If you use an external API, you don't need Pyodide, it just bloats the file size of the extension.
* The background.png (8.3MB) in the website's new UI is too bloated.
Background colors should be described by CSS and image size should be kept under 1 MB at most.
* An option should be added to the extensions to not include cookies as long as the request to the license server is also made by an external API.
Even if this is not the case in practice, there is no way for users to verify that these information is not being misused injustice by the operator of the external API.Don't be stupid.Use your brain and Google.
@FoxRefire I tested the nextgen version on many of the demos and except 2 I can say its working. Vdocipher by default isn't working which is to be expected on account of my emu cdm.
1. https://www.visualon.com/index.php/html5demo/?demo=drm
On this demo there is a problem generating the KID.
[Attachment 79424 - Click to enlarge]
This issue doesn't exist on wks l3.py
[Attachment 79425 - Click to enlarge]
2. Tried on Clearkey demo https://reference.dashif.org/dash.js/latest/samples/drm/clearkey.html
It doesnt allow data input. Given the media file is same as other drm demos, is this supposed to happen? (The key generated is from one of the earlier commonwv demo (https://reference.dashif.org/dash.js/latest/samples/drm/widevine.html) but it works with the clearkey mpd as well)
[Attachment 79426 - Click to enlarge] -
The next version gives the keys as per image/picture whilst the legacy version gives the keys as per wks l3.py
another curiosity is the url
Code:https://www.zee5.com/global/tv-shows/details/kaise-mujhe-tum-mil-gaye/0-6-4z5461626/virat-and-amruta-share-an-emotional-moment/0-1-6z5565798
the next version accomplishes the challenge whilst the legacy fails.
Very interesting -
@Karn
1.
This is not an extension issue, but a Pywidevine (or WKS) issue, so submit the issue to the appropriate Github repository.
Also, since this is only a non-generic KID for demo page, so the same problem will not occur outside of the demo.
2.
Clearkey is not Widevine, but a another protection method where the decryption key is directly in the source code.
Thus, encoded keys can be retrieved directly from the EME Logger.
This can be in KID:KEY hex format with only simple string manipulation; no CDM key pair is required.
The Clearkey key acquisition process itself is completed entirely within inject.js.Don't be stupid.Use your brain and Google.
[Announcement]
WVG now supports Remote CDM.
Usage: https://github.com/FoxRefire/wvg/wiki/Using-with-Remote-CDMDon't be stupid.Use your brain and Google.
I was studying this code
Code:https://github.com/FoxRefire/wvg/blob/legacy/schemes/DRMToday.js
in particular lines 9 and 46
Code:9 if (isValidJson(String.fromCharCode(...new Uint8Array(certBuffer)))) { 46 if (isValidJson(String.fromCharCode(...new Uint8Array(licBuffer)))) {
Everything is great except the routine isValidJson is missing -
This is simply my error.
The DRMToday scheme in the legacy code was not written by me, but was submitted by @Karoolus in #39 and PM.
At this time I attempted to split each process for license servers into separate files to avoid bloating popup.js when trying to accommodate multiple license servers, then I simply forgot to bring the isValidJson() function. (09c6468 and 078268b)
However, after the problem was discovered, I just focused on developing a new version of extension and the problem wasn't corrected.Don't be stupid.Use your brain and Google.
Thanks.
Please continue with your great work. Appreciated.
DRMToday is working great within the legacy framework. -
Hey,
Legacy version(Uses WVCore.Server)
I need help. How should I complete this step? How exactly to install it?
I've already managed it, the extension works properly.
Anyway, is there any reason why you dare to use the legacy version?
There is a new version that has more features and also has careful documentation.
Pywidevine conflicts with my other scripts. -
No, Python runs in the browser, so it does not affect the locally installed Python environment.
sch3m3n0t6upp0rt:y0ucanr3qu3st0rsu6mit
[MPD?]
https://gist.github.com/FoxRefire/fd606ec29a9bfa1f1bef897e0dc3a231
PSSH
AAAASHBzc2gBAAAA7e+LqXnWSs6jyCfc1R0h7QAAAAF84rl36r dHx5HdXaN7isRsAAAAFAgBEhB84rl36rdHx5HdXaN7isRs
License URL
https://shield-drm.imggaming.com/api/v2/license
Challenge scheme
CommonWV
video link:
https://fightclubfree.w3spaces.com/live.html -
can we creat one autonome shema creater with python ?
i am on try to make one if got it i will share here
Is this Widevine or?
By cenkoman in forum Video Streaming DownloadingReplies: 6Last Post: 28th Dec 2022, 15:15 -
Widevine help
By Stevo1987 in forum Video Streaming DownloadingReplies: 16Last Post: 27th Aug 2022, 12:08 -
OSX Mac - Chrome v83 + Widevine L3 extension
By R4p1dH0n3Y in forum Video Streaming DownloadingReplies: 5Last Post: 17th Nov 2021, 14:53 -
Widevine guesser not working
By Hammer in forum Video Streaming DownloadingReplies: 13Last Post: 4th Oct 2021, 11:26 -
widevine decrypt extension for microsoft edge not working
By takheang303 in forum Video Streaming DownloadingReplies: 6Last Post: 3rd Apr 2021, 11:46
